So, all of a sudden, RaceChrono doesn't want to connect to OBDLink MX+ Bluetooth. The adapter is connected in the iOS, and other OBDII apps can read the car's data, but nothing in RaceChrono. There was a Firmware update done on the adapter done recently, but it worked in Racechrono afterwards. Just hasn't worked since yesterday. Any suggestions?
1) Unpair OBDLink MX+ from your phone's Bluetooth settings
2) Pair your OBDLink MX+ again in the Bluetooth settings. You need to press the button on the OBDLink to make it pair again
3) Remove OBDLink MX+ in RaceChrono settings
4) Add the OBDLink MX+ again in RaceChrono settings, using the "Add OBD-II reader" button
Now it should at least connect again.
