Setting up data channels for ND2 Miata
There is another thread where people initially were trying to set up non-standard data channels for ND2 Miata, but it quickly turned into a broader discussion about CAN logging, etc.
https://racechrono.com/forum/discussion/1854/can-bus-data-logging-was-custom-obd-ii-channnels-for-miata-nd2/
I figured it would be valuable to start a new thread with all the important information presented in a more beginner-friendly way.
Recommended setup:
OBDLink MX+ in the "Experimental CAN" mode.
It provides refresh rates of ~40 updates per second, which is significantly higher than what you can get using the regular OBD-II mode.
https://github.com/timurrrr/RaceChronoDiyBleDevice/blob/master/can_db/mazda_mx5_nd.md
lists how to set up the most common/important channels.
  • Some useful custom data channels if you prefer the old school OBD-II protocol:
    Accelerator position (%)
    PID: 0x22032b
    Equation: B/2.0
    (Surprisingly, the standard OBD PIDs for accelerator communicate values in some weird ranges. This PID gives data in a 0–200 range, but at least that looks deliberate)
    Brake position (%)
    OBD-II header: 0x760 (not sure if necessary, what's the default value?)
    PID: 0x222b0d
    Equation: max(0, bytesToInt(raw, 1, 2)) / 2.3
    (You can try other multipliers if you find the number to be too high or too low for you. You can also wrap it with "min(100, ...)" to limit to 100%.)
    Tire pressures, if your Miata has TPMS sensors (I believe earlier model year NDs had indirect TPMS only):
    OBD-II header: 0x720
    PIDs: 0x222a05 (FL), 0x222a07 (FR), 0x222a06 (RL), 0x222a08 (RR)
    Equation: B * 1.373
    You'll probably want to use the PIDs for tire pressures to be set up as "Slow channels". Their values don't change that often, and making them "Fast channels" would consume too much of the limited OBD-II bandwidth, negatively affecting the update rates for the more time-sensitive channels such as pedals.
  • I finally figured out how to decode the brake pressure channel correctly (or at least definitely better than before) and updated https://github.com/timurrrr/RaceChronoDiyBleDevice/blob/master/can_db/mazda_mx5_nd.md accordingly.
  • Hi timurrrr, any luck on finding OBD2 PID for steering angle? :wink:
  • I don't use OBD-II protocol, I strongly suggest using the CAN protocol instead.
    There the CAN mapping for the steering angle is documented on my github.
    (although it might be a little off/buggy, I've seen some interesting data artifacts from NDs on that channel)
  • I'm thinking to buy the "OBDLink MX+" and use the CAN protocol using RaceChrono.
    Question: do I risk to create any permanent damage (or risk some malfunction while driving) when using "OBDLink MX+" + CAN + RaceChrono?
  • I wouldn't want to answer that question in court under an oath, but my best understanding is that OBDLink is a reputable hardware company with a long-ish history and they most likely designed their OBD readers in such a way that it only reads data from the CAN bus when operating with RaceChrono, and should not cause any interference or malfunction.
  • I found some information about gear positions on the miata.net forum.
    https://forum.miata.net/vb/showthread.php?t=616995
    There is information about gears in the spreadsheet shared here.
    CAN ID: 357
    Byte7
    CurrentGear
    Neutral/1st: 19 (dec)
    2nd: 11 (dec)
    3rd: 7 (dec)
    4th: 6 (dec)
    5th: 5 (dec)
    I researched this info using my car.
    I found that combining Byte7 and Byte8 results in a gear ratio.
    Formula: bytesToUInt(raw, 6, 2)
    1st: 5087
    2nd: 2991
    3rd: 2035
    4th: 1594
    5th: 1286
    6th: 1000
  • Hey everyone, I’ve been reverse engineering various codes for the MX-5 ND 2023 and have managed to access oil temperature (calculated, not from a physical sensor), tire temperatures, pressures, and many other data points. Would it be legal to create a GitHub repository with clear, detailed documentation of these codes?
  • Hi alvises,
    timurrrr has a repository on GitHub, that helps me a lot. I think it’s totally fine to publish those information. I also want to do some reverse engineering to access fuel rate and etc. to help assist me in a eco endurance race. If these is any reverse engineering technique article you referenced, please let me know. Thank you!
  • Hey everyone, Been loving RaceChrono combined with the OBDLink MX+. I have used it for a couple track days and have some questions about OBDII + Can. 1) I assume from everything I have read here and elsewhere, I cannot log both simultaneously with the MX+ scanner. 2) What I want are both tire pressures (OBD) and steering angle (CAN). Does anybody know how to pull either steering angle from OBD or get the tire pressures from the can bus? Thanks, Mike
