I must be doing something wrong when using my DUAL 150 with RC...
I had the DUAL 150 receiver added to the RC settings and turned on. Then I go into the BT device list and make sure the 150 is paired and return to RC and start a session, and swipe to the video screen. The video screen shows you there is a connection to the 150 and there are 4-8 satellites (which I think is good.)
There is a message on the satellites screen that says, " A track will be automatically selected when You pass Start line" even though I previously selected the track before starting the session.
Then I press the record video button, I hear a BEEP, and I see the recording timer start to count (top-left.)
After I finish the session, I look in the sessions list, and it says 0 miles, and there is no linked video.
Did I miss a step in the setup or start process? Does the vehicle profile change how RC works without OBD (using GPS only)?
*While* recording, go to the analysis (the graph button on top right), and see if you can see your route so far?
but I will see if I can figure out what happened, since I have more time now.
