is there a way to add custom can channels. now that i am using a diy can-bus device, i have access to data specific to my car/model that isn't in the dropdown list. right now i plan on just putting the data in an unused field and remapping in race renderer. for example, in BMW ZF8 shift settings, S1, S2, S3. its not something i am logging continuously, but if i see a change, i output it.
RaceChrono's channel specifier actually has the position separately. So select "Brake pressure" as the Channel, and then "Rear" or "Front" for the channel postfix (behind the "show more").
I can also add new channel names if you have some that are useful for others.
