CAN-BUS + K-Line
Is it possible to use 2 protocoles at the same time with an OBDlink and RaceChrono ?
On my bike the ECU talks to the OBDLink with K-line protocole, but there is a also a CAN BUS communication between ECU and DASH, so I solded 2 wires from this CANBUS channel to the OBD2 connector, and it works!!!
I can get precious info as rpm / speed / gearing. But connot find throtle position...
I can get the throttle position from the K-Line signal.
Someone know how to get the two signal at the same times ?
Bryan
  • edited September 2022
    In theory with two different OBDLink adapters. One monitoring K-line and one monitoring CAN-Bus. Which bike is it? I would think all important information would be available on both buses.
