I had heard good things about this company and checked their software out...the ability to see where on the track between the edges is amazing and would be very helpfull with overlays between drivers...the rest of the software is simple and clean.
Any chance of an export to this format???...they use a ".bin" but I think it's proprietary.
I suggest you install the demo, then go to help and the second line will install a sample data file...see for yourself. http://www.rlcracing.com/PC_Software.htm
I'm looking for a better analysis program than vbox and danas and I have not found an open source one either.
Are there any forums for racing data loggers and analysis?
thanks,
mr
take a look at Traqview. The session comparisons and such are really good.
Unless I'm missing something, I'm sure refresh rate will have quite an effect.
If your car/bike is travelling at 55m/s (~200Km/h) and your gps updates only 5 times per second then there must be an uncertainty of postition of about 11m between each update.
Of course the software could interpolate between updates which may or may not improve this error but on most tracks I would think 11m would make quite a difference to the assumed driving line. And yes, and top of this update rate error there is also the positional error of the GPS itself.
If one point is a metre out in one direction and the second point is a metre out in the other direction, then your line will not be accurately shown. In a short space of time, drift appears to be minimal though, so whilst the line may not be positionally accurate, it can be compared with the line on the previous lap with reasonable certainty.
From my point of view, I compete in AutoSolo where my speed never exceeds 40mph, so I never travel more than ~3.5 metres between samples, often it's half that. I've found from comparing on-board video that I can trust what the trace tells me about the line I'm taking. It was certainly enough for me to realise that one line was quicker than another and knock some time off.
I suppose if you're cornering at 55m/s, then your mileage may vary!
I do understnad the above posts about accuracy but could it be done and what program would make the track? I'm trying to get the grand master aol thinking about this too...this feature alone is worth the effort imo.
Tentenths - if you really want to see track positions did you know you can export your session to google maps. As andy says though you will probably see yourself off the track and in grass etc alot due to the inaccuracies we have both talked about.
The faster you go the less likely is that the driving line through the corner is accurate enough... Also the line seems to "shift" time to time according the "satellite weather", which makes things even harder.
