I have logged the temperature value of OEM TPMS that is sent from OBD-II, not a separate multi-channel tire temperature sensor (e.g. IR, etc.).
The setting was specified as the 'single' temperature value for each of the wheels FR, FL, RR, and RL for OBD-II Reader channel as shown in the picture above.
In conclusion, I can only see the gray background in the 'Tire Temperature Gauge' in the layout.
Is there a way to use the 'color background' as in the case of multichannel sensors?
Doesn't it show a 'single temperature color' in a single channel per tire, rather than multiple temperature colors of horizontality per tire, as in the case of multiple channels?
What I was saying is that there should also be a way to set temperature thresholds for "solid blue", "blue-to-green" transition, "green-to-yellow" transition, "yellow-to-red" transition, and "solid red".
