Hi there, I use RC (iOS) on the racetrack (Motorcycle) and noticed that in 8.0.3 the lean angle gauge gets stuck at some angle (say 47 degrees) for half a lap, then recovers and shows proper lean angles, only to get stuck again some time later. It is not happening at a consistent lean angel or at a specific point in the lap.....
I am pretty sure it happens during video export as I can see all lean angle data correctly in the iPhone App. I know it is a calculated metric, so maybe something not right in the V8 code (I have never seen this in earlier versions) ??
Anybody else seen this behaviour ?
Thx
Gerd
TY!! Gerd
I'm not seeing anything getting stuck here, when using a real video in the export.
I would have to make all final angle cuts before exporting the video to the iPhone and then apply the overlay - to a 10gb video file for a 20 minute track session …and repeat that process in case I want to edit any cut later…..
That said, we need to know if the issue appears on the normal use case too.
