Racebox Mini won't connect to RaceChrono.
I have a RaceBox Mini that I've used with RaceChrono in the past. Last weekend it would not connect to RaceChrono at all.
Today I was able to connect to the mini with the RaceBox app but it won't connect to RaceChrono. It just says "Connecting to Racebox Mini...". It's connecting to the RaceBox app though. I'm running V8.0.8.
Is anyone else having this issue? Any suggestions?
Thanks,
Chris
  • The RaceBox app needs to be disconnected before connecting RaceChrono. You could also remove the device from RaceChrono and add again, to make sure correct device was selected.
  • edited October 2023
    Hi aol,
    I'm sorry, I should have been more clear. I tried connecting with the RaceBox app, closing it, and then starting the RaceChrono app. That never worked.
    This morning I deleted the Racebox from RaceChrono and then added it again. That worked.
    Thank you for your help,
    Chris
