Version 1.36 known issues for all platforms:
Symbian (S60) version 1.36 known issues:
[li]Phone crash when lights go out in Samsung SGH-i450 and L870. Anybody else experiencing this? Can anyone loan me such phone so I can fix this? [fixed in next beta]
[li]Samsung InnoV8 / 8510 backlight trouble (phone freezes). Workaround is to turn RaceChrono backlight setting to "Always off". Use "S60SpotOn" application to turn on the backlight if needed. [fixed in next beta]
[li]Nokia E62 backlight on not kept light up. Please turn backlight "Always off" from RC settings and use "spoton" software to keep them on. [probably fixed in next beta]
[li]Nokia E82 backlight on not kept light up, anyone else experiencing this? [probably fixed in next beta]
[li]Nokia N95 and N95 8GB have problems with QSTARZ BT-Q818X and QSTARZ BT-Q818 eXtreme receivers. Firmware update on the phone supposedly helps, please let me know if you run in to this one. Not RaceChrono issue, but common never the less.
Windows Mobile version 1.36 known issues (not released yet!):
[li]IMPROTANT: If you're having problems with installation, there one common thing to go wrong. Please use "save as file" when clicking the download link, so you save the .CAB file to your disk instead opening it. Then copy the .CAB file to your device and open it there.
[li]Number editors accept text as well
[li]WIDCOMM Bluetooth stack not supported. If you have it, please configure your GPS and RaceChrono to use a COM: port instead. [will be fixed (hopefully) in next beta]
[li]Loosing editor focus when coming back from another applications (WM std)
[li]Internal GPS setting does not work with HTC P3300 WM 6.0 (but does work with WM 5.0). Any other users experiencing from this?
Feel free to continue the thread with any issues you've found. Please also mention which platform are you using.
1. Load a previous session.
2. Try to set the comparison lap as a lap from a different session. It will say that it is "Loading Session" and hang, i.e. it doesn't present the laps from the other session for you to choose as a comparison.
The only way to exit RaceChrono is to close the application from the task manager.
is there available a 1.35beta version of wondeful racechrono ?
where?
thanks
For Windows computers and S60 2nd edition phones: http://www.racechrono.com/download/
For Windows Mobile phones: Not yet, but soon!
Antti, you are in my Xmas list!
EDIT: Damn I jsut change the setting. I thought I cracked but I did not :(
The same problem is also noticed when the GPS drift happens while on lap on a normal circuit. But all other laps are correct, as the drift on start and finish are the same. :) Oh well, GPS is not perfect ...
Download links available here for beta 2: http://www.racechrono.com/news/?p=242
Cheers
Paul
This is not a problem if i run race chrono in the background with Garmin running simultaneously in nokia Symbian phone.
Similar problem using RC V1.30 in background of omnia I900
I have to unnistall first the old version?
I will wait for the final version, or use the software "signsis"... :P
