first of all, i have a question: say i'm using "60 feet" setting. When does it start counting a new go? from a complete stop? how long have i to be in a complete stop for it to count a new go?
next a suggestion: it currently has 0-100, 80-120, 100-200 accelerations. Would be nice to have custom acceleration, say 0-40 or 0-50.
and finally: would be GREAT if it could also use accelerometer for lateral g and acceleration calculation. I would think that should be a tad more accurate? gtech and similar products use them in great accuracy..
hope to hear your thoughts
Custom tests are in my to-do list, it's coming
is not too hard to make it... in 1 week can you make it?
The GPS data that I've collected is not very good for acceleration data, you have to smooth it out a lot. I put this down to the inaccuracy of the GPS points and a 5Hz this is a large % error unfortunately. The speed data is quite smooth so I just use this to compare runs etc. Applying an averaging to the Acc. data does improve results but they're still a bit rough unfortunately...
Comparing G force data to the Racechrono data this looks to be approx. 0.1s error on a hard standing start, 0-100kph 5.4s.
