List of RaceChrono v1.00 known issues:
[li]Can not edit driver name, if no driver names defined to previous sessions.
[li]GPX export problem with "traveled route" scope: Extra <trg> and <trgseg> tags at the end of the file.
[li]Graph viewer hangs when viewing OBD-II RPM over 8195. Problem goes away when the session is reloaded.
[li]OBD-II time stamp issues.
Please continue the list when you run in to something. You can also submit bug reports through the feedback form in About page.
Only the "Throttle Position" channel is exported to the throttle position field, but I can fix that for next version with your log files.
