I am using the Google Nexus 7 2013 with Android 6.0.1
I recently tried recording a test session before going to a track, and there was no sound in the video. Is there a setting for sound? Is there anything that can be done to correct the problem?
I had to switch to TrackAddict, as it records sound with the video.
Configuration:
1) First, make sure the expert settings are back to defaults. Go to Settings > Expert Settings > Press X - button on top. This will reset your expert settings.
2) Start your session and go to the camera preview screen.
3) Tap the camera configuration box open. Make sure the green microphone button is white (not green). If it's green it is using external (or secondary) microphone. You want to use the primary microphone, as it's the default.
4) Try recording video, and see if audio is captured.
Device:
5) I will upgrade my Nexus 7 (2013) to latest Android and see if I can record audio with it.
6) Your device might also have your primary microphone dead, so you could try taping the external microphone button (so it turns green). See point 3)
Could you use a Bluetooth microphone or headset or earpiece for the microphone? It seems that only phones have a headset jack.
It would be nice to record the sound of the exhaust instead of the sound of you talking to yourself or the sounds of shifting or the steering wheel, which clicks from the tern signal switches..
