I've used gopro 4 for years with RaceChrono but gopro 8 is a real challenge. There seems to be a fight between the gopro app and racechrono for using the camera, and per instructions, the camera has to be connected through the app. Now that I got it to work on some track sessions I can't seem to be able to connect to download the video to the phone. UGH. Even if I get this to work, I have to give up either the bluetooth GPS receiver or the OBD bluetooth receiver because now my camera needs bluetooth as well. Is it all possible in the future to make it wifi only? It's kind of a deal killer and makes me want to sell the 8 and get the 7 instead.
Let's use this thread to come up with some tips from users for gopro 8. I'll post as soon as I find some workarounds.
1) The GoPro needs to be connected through the GoPro app for the _first_ time, to merely pair the camera with the phone. After that the GoPro app needs to be closed, and cannot run simultaneously with RaceChrono!
2) All three bluetooth devices can connect at the same time, GPS, OBD-II and GoPro.
I thought Android can only connect to who BT devices at a time. I know it can remember many more pairings. Ok, will try all three at the same time.
I was also able to transfer the video from the gopro to the app eventually. I had to connect two times in a row to the camera. This was also likely a problem because my go pro app was running.
Nothing against RaceChrono here, it is all about the stupid GoPro app. I mean, even if you try to control the camera in the GoPro software it fails to connected half the time. It's GoGarbage software and now they are forcing us to use it. This is the last GoPro I'll ever buy.
What I do myself when I want absolute reliability, and recommend for my users who complain about reliability of the feature, is to not use it at all! Just start/stop recording manually, and never connect the camera with either RaceChrono or the GoPro's own app. This way GoPro's actually work pretty well. No complaints from me, as long as the Wi-Fi is not used
After manually recording, just copy over the recorded files using a memory card reader (use the RaceChrono's import feature). Then synchronise the video files to your session. There's even "automatic" sync feature for GoPro/Garmin files, which works pretty good most of the time. And you can always do it manually, if automatic sync point is no good. Read more: https://racechrono.com/article/480
Some users really like the Wi-Fi connectivity feature so it cannot be removed, but I accept it's not very reliable, and it's so much work to maintain that it's really not worth it in hindsight. I like the syncing afterwards much better.
