Possible Mistake in the Support Guide for OBD-II Adapters (OBDLINK MX+ and OBDLINK CX)
On the supplier page of your website https://racechrono.com/support, for the question “Which OBD-II adapter should I buy?”, it was said that OBDLINK MX+has a higher refresh rate than OBDLINK CX on both iOS and Android.
But in Harry’s LapTimer, it was said that “The speed limit for the CX is defined by BT LE. All BT LE adapters using the ELM327 protocol achieve the same max speed - which is around 8 Hz. The MX+ is faster when used for Android, but plays in the same league like the CX when used with iOS. This seems to be due to the Mfi integration.”
The link is below:
http://forum.gps-laptimer.de/viewtopic.php?t=6218#:~:text=Re: Questions about OBDLink adapters,-Post by Harry&text=The speed limit for the,CX when used with iOS.
So according to what Harry said, these two adapters work at the same speed on iOS. But on Android, MX+ is faster.
Could the team double confirm and probably fix the support guide web page to avoid the misleading information? Thanks.
