Problem connecting my Samsung phone to QStarz BT-1000eX (5mhz) GPS with RaceChrono Pro
I can pair the GPS to the phone but it does not connect. I assume this would be automatic as I don't see anywhere in RaceChrono Pro someplace to specify an external GPS. The only device that is shown in the RaceChrono->Settings->Devices is the Internal GPS. I did go into RaceChrono->Settings->Expert settings and checked the Bluetooth fix but hasn't helped. Can anywhere say if the QStarz BT-1000eX (5mhz) is supported?
  • Well, as soon as I post I think of another thing to try and it worked. Gotta make sure you go into a new device and select everything and make sure in the internal GPS is unchecked. So, it will be a couple on months until I'm on track again but looking forward to seeing this all work.
  • edited December 2014
    You can select "Bluetooth GPS" instead of the "Internal GPS" from the RC > Settings > Devices. Then just pick your device from the device selection. Only one GPS device can be active at once.
