no laps or laptimes on samsung s5 mini
it shows me session time but no laps or lap times. i do not know if its maybe a setting problem. plz help
racechrono pro
  • edited March 2015
    Most probably a track setup problem. First you need to select an existing track from the library, or create a new one. The traps in the track need to be facing right way (they are unidirectional by default) and there needs to either one "Start/Finish" trap, or one "Start" and one "Finish".
    You can share the session to me by email to tracks(at)racechrono.com and I will take a look what is wrong.
  • thank u so much
  • do i just mail the session file in the folder or all flies
  • Didn't work. Rather than mailing the folders, try using the "Share" button on top of the session screen. Then pick email as the app to share with.
  • did you get the mail i shared
  • Unfortunately the file got corrupted again. Possibly due to email client or servers between. Can you share it in Google Drive or DropBox, so it doesn't get corrupted?
