Adding Traps for new Tracks
I can get to the screen where you see the road map or satellite image, and then you tap the ADD TRAP button to get the bullseye. Then you put the marker to where you want the trap (start/finish line. etc.) to be. How do you save the position? Does it get saved when you press the back button? Also, what are the map layers, besides the road map?
  • Yes, back button saves your changes. Map layers are satellite/roadmap/simple. Simple is just black map overlaid with the data.
  • Unfortunately in current version track is not saved when editor is exited. Going to be fixed in v4.6.4
