CREATE TRACKS - PDF MANUAL
I HAVE 2 REQUEST:
1) Because i race with a kart and have no money to buy Alfano telemtery :), i want use my old NOKIA 3230 to take timelaps and speed. But it is difficult to set the new tracks where i race. Is it possibile to "import" tracks from Lat and Long coordinates to set start/finish and traps of my favourite kart tracks? They Are "Pista Italia" in Castelvolturno, and "Kartodromo Casaluce" in Casaluce, both in Caserta (italy). I can attach the Google maps links. Then i will update them in download section
Castelvolturno 41.016916,13.974025
Casaluce 41.015119,14.195817
2) is there a PDF complete version of the manual insted of web version?
Many Thanks
Roberto Serpico
  • edited April 2009
    i downloaded a .bin file but it seems to be encrypted
    Can you create a .bin file with these coordinates:
    Casaluce start/finish: 41.014287, 14.196050
    Casaluce split 41.015566,14.195841
    Castelvolturno start/finish : 41.016924,13.974009
    Castelvolturno split: 41.016685, 13.973665
  • edited April 2009
    http://maps.google.com/maps?f=q&source=s_q&hl=it&geocode=&q=casaluce&sll=41.034823,13.956757&sspn=0.740653,1.235962&ie=UTF8&ll=41.014742,14.196171&spn=0.002894,0.004828&t=h&z=18
    http://maps.google.com/maps?f=d&source=s_d&saddr=41.016685,13.973665&daddr=&geocode=&hl=it&mra=mi&mrsp=0&sz=18&sll=41.017061,13.973499&sspn=0.002894,0.004828&ie=UTF8&ll=41.016867,13.973504&spn=0.002894,0.004828&t=h&z=18
    edited April 2009
    1) Sorry, the Google Maps satellite photos are usually not accurate enough to set the traps, so you might end up with a track that does not work. Please go run a session first, and then add traps to the logged route (select the position in Traveled Route view).
    2) No PDF version yet, but I'm planning to do it.
  • Is there a way when moving trap in browse traps mode that you can speed up trap movement the longer a button is held? you know so for a large track it doesn't go at a snails pace? (I know I can open trap properties and edit the coordinates but that takes some time too) Just thinking of usability.
    edited April 2009
    Hi Dima, yeah I'll look in to that in the next version! I know there must be quite annoying usability issues out there, so just bring them up and I'll put them to my to-do lists.
    BTW: If you are using a touchscreen phone, you can drag the map while moving. If you have keyboard only, then it's slow as heck :)
  • I live in Sweden and Mantorp is my hometrack. The track on your site is Mantorp long, but there is only a short version of the tracks. After half of the dragster strip it turn 90 degrees right and then direct 90 degrees right again and out on the start/finish. How can i create this track? Can i modify the Mantorp long?
    edited May 2009
    Hi Kotten, you can edit the long track:
    1) download the Mantorp long track through "Track profiles > Options > Download new".
    2) Open the track in "Track profiles"
    3) Change the name to "Mantorp short" or something...
    4) Switch "lock traps" to "disabled"
    5) Run a session with this track
    6) Go to "Browse traps" and just delete the traps you do not need, and possibly modify one of the traps to "Start/Finish" if you just deleted the old start line.
    7) You can also add new traps by moving in the "Traveled route" and then "Options > Add trap"
    8) Upload the track to me for track library :)
  • nice, thanks. next trackday is 12-may. I will try to do this then.
