OBD response prefix check is not applied to the CAN ID part of the response.
I have found two sensors in GR Yaris that share the same PID but have different OBD Headers (CAN IDs):
Steering Angle
Header: 7B3
PID: 221004
Brake Master Cylinder Pressure
Header: 7B0
PID: 221004
Here are the CAN messages that are generated with such OBD configuration for brake master cylinder sensor:
Request: 0x7B0 03 22 10 04
Response: 0x7B8 04 62 10 04 0A
However responses to the Steering Angle requests also have the same response prefix (04 62 10 04), because both sensors have the same PIDs.
RaceChrono should automatically match responses by response CAN ID, which is request CAN ID + 8. Or full response message with CAN ID should be matched against the response prefix if set in the configuration.
Currently, when I have both of such PIDs configured in RaceChrono, responses are shared across both channels.
Please follow these instructions to generate debug data. Make sure both "offending" channels are enabled.
1) Please turn on "RaceChrono > Settings > Expert settings > Save device output".
2) Then record a session while connected to your OBD-II reader. It is connected if the "Connecting to..." goes away and does not appear again. Short session with GPS lock, and the OBD-II reader connected is ok. No need to be at a race track, just a casual drive around is fine.
3) Please share that session with me (using the share button, that generates a .rcz file). Please email to tracks(at)racechrono.com
I may have sent you down the wrong path. Initially I noticed the problem in the channel configuration page where live data can be used to see values of all of the configured channels. On that page values are jumping for channels that share the same PIDs. I've sent you a recording of that screen to the email you mentioned.
wanting to add this to my next GRY track day with RC. _/|\_
Thanks for your help @dvim, im running similar but for brake pedal %. I adjusted the 0.95 value so with foot to pedal stopper the % was at 100.
