Importing VBO files from Solo Storm
Has anyone been able to import VBO files exported from Solo Storm? This would be a massive help which I and probably hundreds of people would use routinely.
  • edited June 5
    The issue was found by a friend of mine. When Solo Storm exports a VBO file, the first line is exported with an issue (two digit year) and RaceChrono will reject it. You can fix this in notepad and it will import no problem.
    ISSUE: File created on dd/mm/yy at hh:mm:ss
    SHOULD BE: File created on dd/mm/yyyy at hh:mm:ss
