First time user of the SW. running it with a nokia BT GPS dongle and everything considered, really really neat. My girlfriend is happy not having to stand stopwatch in hand in the cold, i get laps and splits, neat, Thanks a lot!
only weird thing is that analyzing my first race results from Vallelunga in rome, The speed graph seems WAY off.... there's just no way that some third gear turs show as only 50 kmh, ditto for main straight. by gear's/RPM calculation 9500 is 220-225 kmh, graph shows 180...
Any idea as to why this big gap? it's a good 25% off.
Other than that, really nice!
I think the Nokia GPS with only a 1hz update rate and SiRF Star III chipset is probably the most likely cause of the inaccuracies if in fact there are any.
i race a vintage kawasaki 750 that's been dynoed 90 rwhp, weights 165 kgs, so together with my 85kg is about 360 hp/ton.
in any case, spent some more time now with the graphs, as well as with the gearing calculator and looks like i was checking with the wrong final ratio. seems now like i was hitting more like 190 km/h before the brake marker while with the right gearing i should be getting 200km/h, guess that a 10% mistake in the revcounter is reasonable, and in any case not easy to read it when you are bent over the bike at full speed.
so mistery sorted, sort off....
thanks you all
TG
