Notice: If you're getting crashes on your phone, Android system will ask you to submit a crash report. Please do so, because then I can instantly see the stack trace of the crash!
This is the current bug list for v2.20. Note; This thread is now closed, so If you have a new bug, please create a new thread for it (if similar thread doesn't already exist).
The bug list
- App crashes when opening a library track, and pressing back immediately
- No trap/split labels on .CSV exports
- Problems with .CSV exports, for example RaceChrono2AVI is giving different lap times compared to RaceChrono
Not bugs, but important stuff I did not have time to do yet:
- Performance testing
- Editing session name and description
- OBD-II and RaceDAC support
- Missing importing (NMEA etc)
- Missing raw NMEA saving while recording
It is not important but I wanted to report it :
I do not yet have android phone ... but i have an android notebook. This is the Toshiba AC100, the Android version is 2.2 (kernel 2.6.32.9). This notebook has no internal gps and no bluetooth. It has a USB port and WiFi. It does not have access to the android market.
RaceChrono preview apk will not install on this hardware. (Yes I checked 'Settings > Applications > Unknown sources' is enabled.)
I have been using racechrono since you released it for android, and it works quite well. Except for the connection between my phone, HTC Wildfire, and the GPS device I am using, iblue 747 A+. They connect together at the begining of the session, most of the time I get 10 satellites, my phone starts recording, and at the end of the session when I look at the screen it says "no gps connection". I guess the bluetooth connexion between the devices gets lost and they cannot connect again. It's really annoying because when it works the lap times are very accurate as well as the map.
Thanks,
Fred
Thanks.
I am having a problem with recording at 10hz, its missing data. From research, I found comments talking about Cpu speed in phone not up to the task and got the impression(Trackmaster Forums) you need at least a 1Ghz Android Phone for reliable 10hz data logging.
I beleive this is not the case as i was originally using Racechrono on a HTC Wildfire 600Mhz CPU which would not give me reliable 10hz recording (work phone), i have since purchased a Samsung Galaxy Player 4.0(1Ghz CPU) hoping it would be able to record at 10hz. I was suprised when i couldnt log 10hz without missing data from the Samsung.
I could do 5hz perfectly on the HTC and the Samsung. After hours of playing around myself trying to get it to record at 10Hz. I managed to do it but only if i unpair Qstarz BT-Q818XT from my phone, start racechrono, press start to begin logging and then it pops up asking for me to pair Qstarz to the phone and enter number, i do this then racechrono records perfectly at 10Hz. The strange thing is after i worked this out i tried the same procedure on my HTC and it recorded 10Hz perfectly as well. If i stop recording in Racechrono then start recording again without unpairing it goes back to missing data at 10Hz. This only works if i do the pairing in Racechrono, if i do the pairing in the bluetooth system window then start racechrono it doesnt work. I have tested this a lot and it will only reliably log 10Hz if i go through this procedure every time, 5Hz works as expected on both phones
I realise it may not be a problem with Racechrono but was hoping for your thoughts on this.
Samsung Galaxy Player 4.0(rooted and custom kernel/rom) 2.3.5 Gingerbread
HTC Wildfire (stock) 2.3.5 Gingerbread
HTC Wilfire 2.3.5
Samsung Galaxy Player 4.0 2.3.5
Meanwhile I will try to reproduce and fix the issue.
I am exporting sessions recorded with the previous version.
Is this still an issue?
Thanks.
