Hi, as you have a TT on your webpage am i correct in assuming it can read VW/AUDI obd measured values? i have access and can pair my 6110 navigator phone to the genuine obd connector, my GPS signals are good but it will only show speed, direction, altitude, ets (only gps readings) on the live timer - is there another area to go to or does the program not work with this unit?
Cheers
The feature uses the standard OBD-II protocol and should therefore support all the cars that support OBD-II (all cars after 2001, and some before). So it is not limited to any car model. But it is tested only with the Car-pal and Obd-key readers, others probably won't work.
I'm not sure if it's possible to have problems with other cars than the models we have tested, due to the fact that the protocol is a standard. It might be that in some older cars have more limited set of channels to monitor, and none of the channels that are defined in RaceChrono, are supported.
I admit the OBD feature does not provide the user with enough information of the status of the OBD-II reader. There really is no way to know what is going wrong if there is a problem. This is something that I should improve on future versions.
Also enable all channels in the settings, to test if any of them works.
I can log the OBD data (mine is Mazda RX-8), and the high priority data are able to plot on the graph.
Have not seen teh gauges on the screen yet, and just realise I have to press the right key or something. Maybe that is what i have not done.
EDIT:
Check it again, Right button works.
Info: The new BMW 135i = I cannot get RPM logging!
Now we are doing some performance 0-100km test from OBD. We did a 4.95 and we are so happy. Until I saw the graph saying that the GPS speed at the time is still at 89kph! and we actually just did a 5.7! :(.
So can we have an OBD to detect start and GPS to record speed? Would that be the most accurate?
2) About the false 0-100 kph reading, it might be closer to the truth you think, since it might be that OBD and GPS speeds were bit "unsynced". Does the GPS speed graph start later when compared to the OBD speed? It is true that OBD-II lies a bit, on my car 100 kph in OBD is 97 kph in GPS. Might be that the car did 0-96 kph in 5 seconds, not 89 kph.
I think there should be "OBD speed calibration" feature which would adjust the OBD-II reading with GPS speed. Also better timing sync between OBD and GPS, but that is already hard to do.
BTW: Be sure to join the beta group, you'll get updates to the OBD-II sooner that way. :-)
2) Yes the GPS lags a bit. What does that mean? Does it just mean the GPS take time to activate? ... I got what you mean. So we just have to determine what the GPS speed is in constant OBD = 100 kph. You are a smart man!
Back to the drawing board.
Following features are coming but did not make to the beta version:
* OBD-II speed calibration with GPS (more accurate 0-100 kph with OBD)
* OBD-II sync with GPS (time difference) (more accurate 1/4 mile with OBD)
* List of all OBD-II channels that are supported / currently being logged.
