I've just released RaceChrono v7.2 for Android to the beta group (
https://racechrono.com/article/faq/how-do-i-join-the-beta-group ).
UPDATE v7.2.1: I've made small changes to the Overlaid video exporting, please test that it is still working on your device!
Change log for RaceChrono v7.2.0:
- Added support for OBDLink CX
- Added importing for Tesla Track Mode files (.csv)
- Added importing for iRacing telemetry files (.ibt)
- Added many new custom channel names
- Improved: OBD-II custom channel PIDs (requests) are now allowed up-to 8 bytes in length
- Fixed: GoPro video files embedded GPS data was not always imported properly
- Fixed: Air/Fuel ratio -channel was not available for custom channels
- Fixed: CAN-Bus data logging using OBDLink reader was broken for PID numbers less than 256
- Fixed: CAN-Bus channels were hidden in Vehicle profile if there was no reader device configured
- Fixed: bitsToUintLe and bitsToIntLe did not always return correct values
Change log for RaceChrono v7.2.1:
- Improved: Audio codec support in video export
- Fixed: Location permission request was broken (since 7.2.0)
Change log for RaceChrono v7.2.2:
- Added importing for AIM Data Logger files (.csv)
- Added 5 Hz support for Transystem GL-770
- Added new custom channel names
- Fixed: Broken .fit file import from Garmin Fenix 6X Pro
- All languages fully translated
Change log for RaceChrono v7.2.3:
- Removed redundant Rear brake position -channel
- Fixed: Broken AIM import
- Fixed: Always display video window when opening analysis from the video list
Change log for RaceChrono v7.2.4:
- Support for GM VPW DPIDs
- Improved: Engine load -channel is now available for custom channels
- Fixed: Clunky Media permission usage on Android 10 and later
- Fixed: Storage or Media permission was not properly requested when importing
- Fixed: OBD-II data logging failed if reader power was lost at any point during a session (readers with Bluetooth LE connection only)
- Fixed: AIM and Tesla Track Mode data logger channels not properly imported on Android 7.0 and earlier
- Fixed: AIM and Tesla Track Mode import data logger channels resolution
- Fixed: Possible end-of-session crash
Change log for RaceChrono v7.2.5:
- Added experimental support for Wit Motion BLE 5.0 IMU-sensor
- Fixed: OBD-II connection initialisation failed sometimes (OBDLink LX for example)
Change log for RaceChrono v7.2.7:
- Fixed: Crash when resolving device delay
- Fixed: The last "in lap" was not displayed in the lap list
- Fixed: Incomplete laps displayed as 0:00.00 in Analysis screen drop downs
- Fixed: Missing rounding in live lap timer
Change log for RaceChrono v7.2.8:
- Fixed: Broken audio when exporting overlaid video (Samsung S21 and possibly others)
Very happy with this new version
There is a small problem with the units :
Example the speed in km/h
The OBD returns a value in km/h and not in m/s.
At the end of the calculation you consider that the speed is in m/s so you multiply by 3.6.
This is not difficult to correct,
Same thing for the powers in kW and probably others.
Yeah, I was previously confused by that too. Perhaps there should be a note explaining the expected units when defining a custom PID for such channels?
Moreover today I recorded a new session (from repair shop to home) but it appears under 2020 session, dated 13/11/2020 (but the time is ok)
Did a drive on open roads (no start/finish). Wanted to export a part of the drive (*.rcz). The drop down only has option "whole session" but I could edit start and end time to what I wanted. But when I ran the export it saved the whole session and not the start and end I'd chosen.
Just some FYI. The sync of OBD2 data with GPS data using the two speeds is superb! Worked perfectly with logs from my BMW M2. But my Toyota GR Yaris sends OBD2 data with the speed at 200ms offset to all the other OBD2 data channels hahaha. Sooo stupid. I'll do a test with fewer fast channels, maybe I had too many to actually get the data in time (due to testing I had two throttles, rpm, timing advance, air/fuel and speed)
@aol Yes ๐ would be cool to find brake pressure and steering angle also.
https://racechrono.com/forum/discussion/comment/11438/#Comment_11438
Steering angle brake and accelerator are quite easy to discover with this method.
PS: GR Yaris *-*
Also: a channel for engine calculated load [%]
